Transform points into a grid.
1925 5 0- swarmagent
- 17 posts
Hello everyone,
I'm a noob to Houdini and falling in love with it. For quite a while now I've been trying to transform a collection of points into a grid. I have tried various techniques with my limited knowledge and reached the point to give up. Can someone please help please.
I have tried for-loop and wrangle nodes, but always end up with a diagonal transformation. I really would like to do something like the code below but with existing points.
for (int n=0; n<10; n++)
for (int i=0; i<10; i++)
addpoint(0, set(n, i, 0); //If I substitute this with @P += set(n, i, 0), I get diagonal layout.
I'm sure there is a better a approach. I've even tried it with a copy node, but I can't get the individual element to copy on each point, it would just copy all the points onto the given grid points. I've been speed learning Houdini for two weeks and a bit embarrassed to ask for help for something that might be a trivial thing.
I appreciate any help. Thank you.
- BabaJ
- 2042 posts
- anon_user_40689665
- 648 posts
- swarmagent
- 17 posts
Thank you BabaJ an cpb for the response, I really appreciate it.
I realized that I don't need to arrange the Primitives in a grid fashion. Honestly I just wanted to learn how to manipulate a set of clustered primitives, but I'm too dumb to understand Houdini's VEX. I've attached my files to show what I've been doing.
My goal is to go trough every cluster of primitives and generate strips that matches the the silhouette/volume of the curves.
UV the strips and bake out a texture. Basically, I'm trying to make a polygon strips from the curves and generate game friendly hair textures.
I know my goal this is of topic. Again, I appreciate your help. I just have a lot VEX learning to do.
- 648 posts
- Benyee
- 59 posts
swarmagentcan u attach the hair shell object?thx
