ROP HDA missing genericTool attribute
   1610   4   1
Is creating ROP HDAs any different then SOP?
I wrapped Null in Subnet, created versioned HDA from Subnet.
Once I drop down this newly created HDA, I get this error:
  File "driver_farmsubmitter::1.0", line 2, in <module>
AttributeError: 'module' object has no attribute 'genericTool'
Any clues?
Thank you
Screenshot 2021-05-03 225751.jpg (23.0 KB)
Michal Tas Maciejewski @ www.vfxtricks.com
Solved.
It works fine when I create HDA via standard Create Digital Asset.
Breaks via Versioned Digital Asset
I wonder how are HDAs different, I thought its just naming and pathing that Labs is handling.
I don't see any scripts in Labs generated HDA.
Edited by tas3d - May 4, 2021 09:41:44
tas3d
Solved.
The LABs asset manager is probably going through the same teething pains that our production asset managers went through when we had to discover all the gotchas in using HOM to script HDA creation, such as not creating default tool scripts.
Labs is an experimental playground, not a stable supported product.
Cool no worries. Create Versioned DA is very useful.
Hopefully Paul Ambrosiussen will have a look at this.
I believe this issue has been fixed some time ago. (Early June)
If you're still experiencing this, please update Labs
Paul Ambrosiussen
Technical Artist, Freelance
twitter.com/ambrosiussen_p
