Hi all
i'm curious to try my gtx1070 with flip fluids, but even though it's selected in the miscellaneous settings and i enabled opencl in the solver, the gpu doesn't seem to kick in at all. I used “hgpuinfo -c” also which doesn't show anything wrong on my video card.
Nvidia drivers 432.00.
Is there another way to enable it?
Houdini 17.5 - OpenCl flip fluids not kicking in
2147 3 1- Flatland
- 43 posts
- Enivob
- 2539 posts
No, OpenCL only works on limited resolutions. Most vRAM is not large enough to hold a decent simulation. You may have set your FLIP resolution too “high” with a low particle separation. When this happens Houdini politely degrades to CPU calculations, instead of GPU calculations. This make OpenCL more of a “toy” to play with, rather than a production acceleration tool.
How are you monitoring your GPU usage?
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- Flatland
- 43 posts
- olivetty
- 20 posts
I have 2x3090 and OpenCL on fluids still feels like it makes it worse than if it's on. The only time I see a benefit of it is in the pyrosolver and axiomsolver (duh!). Feels like it needs a rehaul!
Mage level 2
www.headofoliver.com
