Hey all,
Just testing out Karama XPU and I noticed the texture resolution of my renders seem much lower with XPU vs CPU render. I'm wondering if there is a texture resolution limit settings somewhere or if this is hard coded as part of the alpha?
See CPU and XPU render comparison attached.
Thanks,
John
Karma XPU texture resolution limit?
2940 3 2- johnp
- 10 posts
- protozoan
- 1630 posts
There's a limit of 2K per default at the moment.
To go further, set the env variable KARMA_XPU_MAX_TEXTURE_RES, for example:
for 8K max.
Careful: The memory management right now is a bit experimental. Use very carefully.
export KARMA_XPU_MAX_TEXTURE_RES="8192"
for 8K max.
Martin Winkler
money man at Alarmstart Germany
- johnp
- 10 posts
- Strangeland1
