Hi.
I have 4 Animations/Simualtions. All of them are running on the same mesh with the same vertexcount/order
How to i merge those anims back to one mesh animation?
Second Question.
How do i fuse the vertices of an animated alembic mesh?
thxs for any help
Guido
Merge Alembic Files
3770 7 0- Guido Neumann2
- 8 posts
- sepu
- 419 posts
For your second question, you need to unpack and convert or just convert and use a fuse node.
For the first question, do you have all these as alembics files? if so just add a merge node and drop a ROP alembic and just write that into one.
If you have different sims, obj merge all the outputs into one geo node and again you can merge all of them and drop a ROP or go to file > export > alembic (you can use this for both options, sims or abcs)
Edited by sepu - Dec. 30, 2021 13:44:13
- Siavash Tehrani
- 710 posts
Guido Neumann2If the point count stays consistent between the meshes and throughout the animation range, you can use the Blend Shapes SOP to combine their animations into one model by keying the blends.
Guido Neumann2By default, alembics will come in as packed poly soups. Change Load As to Unpacked on your Alembic node and append a Convert SOP. You should be able to fuse now.
Second Question.
How do i fuse the vertices of a animated alembic mesh?
- Guido Neumann2
- 8 posts
- Guido Neumann2
- 8 posts
- sepu
- 419 posts
- Guido Neumann2
- 8 posts
- Guido Neumann2
- 8 posts
