How do i submit chunks of frame ranges at once in HOudini please? The way to do it in 3ds max is “0-25, 50-100, 150-175” and that does the trick. Not sure what the synthax is in Houdini.
A.
Submitting several frame ranges at once to render?
7450 12 4-
- Adriano
- 411 posts
- huey_yeng
- 69 posts
As a Max user, I do miss this feature when trying to re-render specific bad frames from Houdini.
Take a look at this thread over at Odforce: http://forums.odforce.net/topic/16331-render-unconnected-frames-at-once/ [forums.odforce.net]
I ended up duplicating the Mantra nodes and set the frame range manually.
- Adriano
- 411 posts
- The3DStig
- 130 posts
- BabaJ
- 2167 posts
Interesting…I was researching today how to do something different, but it relates to this thread.
In your hip file out context you could have multiple copies of the same mantra node…with different frame ranges.
Then just run the renders in the command line:
render mantranode_1
render mantranode_2
render mantranode_3
etc.
but even more simpler, just research a bit of python on how to enter strings into a paramter ( in this case frame range of the mantranode )
render mantranode_1
python // whatever the python code is here for specific range
render mantranode_1
render mantranode_1
The above isn't technically correct ‘code’, but it gives you the idea.
Varomix in his tut goes into more detail, prettry sure you can get it done following his tut, and a bit of python research.
https://www.youtube.com/watch?v=28mnARbQbLg [www.youtube.com]
render mantranode_1
render mantranode_2
render mantranode_3
etc.
render mantranode_1
render mantranode_1
render mantranode_1
- Grendizer
- 392 posts
- peeeeeef
- AhmedHindy
- 146 posts
peeeeeef
I know this is a very old thread, but in case someone runs into this issue again, duplicate your render rop nodes, connect them all to a merge, and the merge to a batch render node. Make sure to use "render frame range only (strict)" in the range settings. Happy renderings !
I don't understand it quite well, why duplicate?
shouldn't we just merge them all and add a batch render and choose "strict"?
- toonafish
- 564 posts
- Digipiction
- 166 posts
toonafishYou need to disable <Non-Blocking Current Frame Rendering> on the Redshift nodes for it to work.
I just tried this setup with 3 Redshift ROPs set to different "strict" frames, but I can't get it to render all the input ROPs. The batch only renders the frame of last ROP in the "merge", no matter what setting I use .
Did anyone get this working ?
- Digipiction
- 166 posts
- toonafish
- 564 posts
- AhmedHindy
- 146 posts
