Hi All.
I have been playing around and had no joy in trying to create a constant unshaded material using only the Material X LOPs.
I could hack this previously with a principled shader assigning a color/image to the Emission Color and turning off "emission Illuminates Objects". Does anyone know how to do this.
All the best. Mark
Karma: materialX Constant unshaded surface: how to
7536 9 1-
- Mark Wallman
- 821 posts
- 8380 posts
Use the MtlX Uniform EDF to create a constant (unshaded) shader.
https://www.sidefx.com/docs/houdini/nodes/vop/mtlxuniform_edf.html [www.sidefx.com]
There is no turning off 'emission illuminates objects', for that set the bounces to 0.
- Mark Wallman
- 821 posts
- Petfactory
- 18 posts
jsmack
I am quite new to Lops, how do I set the bounces to 0?
Regards,
Johan
- 8380 posts
Setting the bounces to 0 is done on the karma settings node. look for limits.
However, in the case of the original thread, setting bounces to 0 is unacceptable. To create a constant shaded object that doesn't contribute to lighting, add a render geometry settings node and set the render visibility to invisible to secondary rays.
Edited by jsmack - June 11, 2022 14:48:34
- Petfactory
- 18 posts
Thank you for your quick answer.
It works perfect. In the render geo settings, I set the shading > render visibility to "visible only to primary rays" to also avoid having the geo cast shadows.
It seems like the mtlxuniform_edf only works in the cpu engine. It would be really nice to be able to use a "constant unshaded surface" in the gpu engine, do you know if that is possible?
- 8380 posts
Petfactory
For now, the beta XPU engine has limited shader support. It only works with standard surface and usd preview surface, and a couple others for hair/volumes. I expect support to be expanded in the future as it matures.
- Petfactory
- 18 posts
- jlapre
- 135 posts
jsmack
Very helpful.
Jeroen
- brians
- 626 posts
