I am trying to follow along with some basic tutorials and hopefully learn the software. I was following a table top tutorial and found that polyextrude was not behaving the same as what I was seeing in the tutorial, but didn't seem to be functioning as I thought it should be. Hopefully someone can help me out.
I started with a 1 x 1 grid with 2 rows and 2 columns. The connectivity is quadrilaterals and the primitive type is polygon. I then add the polyextrude below that. As soon as I adjust the distance, the object goes from a rectangle to an extruded half sphere. Why is this happening? Should it not remain as a rectangle?
polyextrude on grid not working as expected
1016 4 1- grantstaley
- Enivob
- 2537 posts
- 7771 posts
Enivob
That looks like the result of a subdivide node. Do you have one in your network? If you do, change the algorithm to OpenSubdiv Bilinear.
I don't think so, it looks like viewport subdivision. You can tell by the wireframe not matching the surface.
Hit the ctrl-minus key combination to disable smoothing on the current object.
- grantstaley
hi All,
Thanks for the replies, really appreciate it. As learning any new software...big frustrations with simple answers.
I ended up just starting from scratch so that all the default settings were reset. That seems to have fixed whatever the issue is. I will have to remember the "ctl-minus" if I see it again. I am sure when I was trying to add a node, I forgot to hit tab first, which I am sure caused me to hit some kind of hotkey for something.
All resolved now. I was trying to cancel this post but It had to go through admin since my first time.
Thanks again for the help.
- 7771 posts
grantstaley
hi All,
The draw mode of each object is also in a menu on that object's parameters which helps if you forget the hotkey.
Edited by jsmack - July 18, 2022 12:26:16
