hi
i did this in xsi, i create a script that did:
for each edge i compare the neighbor polygon normal, and how big the angle between those 2 vector if the angle is less than my specified treshold value the edge will be deleted.
now how can i do it in houdini, does anyone knows?
is it posible to do it via vop? (does anyone knoe how can i do iteration on edge or polygon in vop,it seem that it only works with vertex ?no?)
or via sop is it possible?
thx patar
how can i do "it" in houdini?
5015 4 1- patar
- 280 posts
- jason_iversen
- 12467 posts
While actually doing this in Houdini yourself is not easy without using the HDK (the Houdini Development Kit), you can get a similar effect using the PolyReduce SOP with “Preserve Original Points” and a high value in “Edge Stiffness”. Try that out and see if it helps you get what you want.
Jason
Jason
- ben simons
- 387 posts
Also, take a look at the “Edges” option in the parameters for the Group Sop.
(UnEnable Number, Select Edges, then Enable it, then enable Edge Angle)
It adds prim's to the group if the angle between 2 surfaces along an edge
is above a certain threshold. Once you make a group you can do things to it…
Not quite what you want, but it might help.
cheers,
b.
cheers,
b.
''You're always doing this: reducing it to science. Why can't it be real?'' – Jackie Tyler
- edward
- 7717 posts
- Simon
- 2199 posts
