Hello dear community members, I am running into a topic and I can't wrap my head around. I am trying to build an channel expression dynamically, that is changing via user input. My idea is to bind specific elements of the expression into string attributes, that builds the complete expression (string attribute) depending on the input.
For instance the functions are separately, the locations, and every other element in it. Everything is coming together and should be pasted in a float channel (because the actual expression is referencing float data). But it does not seem to work, probably because of the attribute class being a string. But is there a way to tell Houdini like "evaluate the expression and convert it into its actual value"?
I am not sure, if this is how things can work inside Houdini, or maybe there is another way of doing such things? Putting an "atof" in front of the string expression does not working either.
Thanky you very much
Dynamically changing Expressions
908 4 0- Irinel
- 12 posts
- 8589 posts
- Irinel
- 12 posts
- 8589 posts
- Irinel
- 12 posts
