The Houdini documentation says this about the "Color POP"
https://www.sidefx.com/docs/houdini/composite/export.html [www.sidefx.com]
"Colors particles based on the pixel colors of an image. It has an explicit option to take data from a COP node instead of an image file."
The COP option is exactly what I want to do but the link in the documentation is broken. I have found the "POP Color" node but this does not have an option to point to a COP.
Any suggestions as to how to achieve this?
Color particles using COP
710 2 1- DarrynRogers
- 18 posts
- 7803 posts
You'll need to project the points into some sort of image space. Once you've done this and have a texture coordinate, feed that coordinate into a texture call. The texture call can take a path to a composite node where it would normally take a file path.
for example, in the POP Color check "Use VEXpressions" on the color tab and enter
color = colormap("op:/img/imgnet1/mycop1", @uv.x, @uv.y);
- DarrynRogers
- 18 posts
