Why is this Fluid surface flickering still happen?
2965 2 0- Muhammad_Afiq
hye, im still facing the fluid surface flickering after i had follow all suggestion on the internet.
*I'm making slow motion fluid movement, 120FPS
this is what i did:
1. Particle Fluid Surface Node - Turn On Limit Refinement
2. Particle Fluid Surface Node - Turn Off Rebuild SDF (inside node content)
3. Particle Fluid Surface Node - Change to Spherical Method
3. Particle Fluid Surface Node - Set Adaptivity to 0
3. Flip Solver Node - Reseeding Turn Off (but AutoDOPNetwork lock the option, so i cant turn Off)
this is what i did:
- juancarlosgzrz
- 6 posts
- Heileif
- 130 posts
