I have made two groups at different location for a points on grid.
How can I view them simultaneously? Merging them together in a merge node doesn't help. Adding color also doesn't solve the issue.
Viewing groups simultaneously?
928 6 0- proceduralist
- 188 posts
- CYTE
- 679 posts
- proceduralist
- 188 posts
- CYTE
- 679 posts
Why do you create the groups not one after the other in the first place?
You want to see stuff that is blocking each other. You get two grids this way?!?
and to see groups you have to set the group and attribute display to groups via the gear icon...
CYTE
CYTE
Edited by CYTE - Sept. 14, 2023 14:30:47
- Siavash Tehrani
- 710 posts
- BabaJ
- 2041 posts
proceduralist
You can use the group combine node, giving it a unique name to choose from while retaining the original names for independant consideration of other operations.
Edited by BabaJ - Sept. 15, 2023 07:38:42
- proceduralist
- 188 posts
CYTE
CYTE
No particular reason. I was doing it wrong. I realized I was being stupid. Using a null as guided by Siavesh solved the issue.
Siavash Tehrani
Make sure you select Groups from that dropdown (should be set to that by default). It's context sensitive, so if you're in point selection mode it will only show you point groups. Also be mindful of what CYTE mentioned: You are doubling up your geometry by merging it like that.
Thanks. Now I understand.
Edited by proceduralist - Sept. 15, 2023 12:52:39
