Hi!
I've got 2 nearly identical curves (one is a copy of the other). The only difference is a slight position change but the point numbers are identical. When I use polyBridge I end up with lines that converge on the sides. Is there a way to force a perfect quads-only pattern?
Poly Bridge topology is funky [{SOLVED}]
364 2 1- olivierth
- 1010 posts
- olivierth
- 1010 posts
Ok, I think I found the solution. in the PolyBridge sop, under the Bridge tab, there's an Explicit Pairs section all the way at the bottom. All I need to do is pair the first point of each curve. So if my first curve has 66 points, the pairing will be 0 and 66 (first point of each curves). That seams to fix all my problems no matter what curves I bridge together!
-Olivier
-Olivier
Edited by olivierth - Jan. 23, 2024 10:41:16
- 8595 posts
