The "Save as Default" button in Display Option window seems to save settings as global default. How could I, for example, save display options per desktop, so when I load a desktop the corresponding viewport display options are loaded too?
How to manage viewport display options?
1452 4 1-
- kodra
- 373 posts
- 8177 posts
- kodra
- 373 posts
- 8177 posts
kodra
But not all, which is the problem.
What I'm trying to do is to quickly switch between two or three sets of display options, just like if one has two sets of commonly used window layouts, they can quickly switch between them with desktops. Is it possible?
hmm, not that I know of, but it could probably be accomplished with a script.
- Jonathan de Blok
- 294 posts
https://www.sidefx.com/docs/houdini/hom/hou/GeometryViewportSettings.html [www.sidefx.com]
Looks easy to script, almost all of those values can simply be put in a json file for saving and loading.
I ran into this as well a few times but more on a per project base. Different project using different viewports, I might make something for this if I find the time.
More code, less clicks.
