In Houdini 19.5, I set up the OCIO with the ACES 1.2 to houdini.env. I saw the correct OCIO 1.2 config file loaded in Edit>Color_settings>Color_correction and I saw in Render View in Color Correction bar that ACES + sRGB is being used. Everything was working properly.
In houdini 20, If I set up the same way, that doesn't work. The previous render in the gallery and the new one are wrong and didn't match the colorspace that I have with aces 1.2 in houdini 19.5
Whatever I do in the new OCIO editor that doesn't fix it. even when I changed exr colorspace to ACEScg to fix the snapshot that doesn't work.
So how can I fix the gallery snapchot with the correct colorspace to have the same render saved in the 19.5 and 20 and how to add the ACES 1.2 properly on in the new OCIO setting ?
Thanks in advance
Houdini 20 - OCIO - ACES 1.2
495 2 1- Tukifri
- 5 posts
- 7794 posts
- Jonathan de Blok
- 253 posts
