Sloww startup
5649 26 3-
- Mirko Jankovic
- 279 posts
- Heileif
- 280 posts
- alexmajewski
- 109 posts
- Mirko Jankovic
- 279 posts
- alexmajewski
- 109 posts
- Mirko Jankovic
- 279 posts
- Heileif
- 280 posts
- alexmajewski
- 109 posts
Damn and I thought our studio's 1 minute was bad. RIP
Linux has a faster everything. Mplay pops up faster too, Husk is quicker to start. Someone once told me Windows' slow Houdini startup is related to some sort of internal virus scanning thing, that if you disable all defenses it boots up fast. Not sure if I'm willing to test it
- raincole
- 692 posts
It's ridiculously slow. Even with the Windows Defender off. I don't think there is another DCC that takes so much time to launch (not even Maya).
It's so slow that every time I launch Houdini I launch 3 blank instances just in case that when it crashes I can use another one immediately.
I wish I'm joking.
I wish I'm joking.
Edited by raincole - Feb. 21, 2025 17:51:15
- johnmather
- 653 posts
You can get an idea of where the time is going by running:
You can then load that file into the Performance Monitor for analysis.
If you have labs installed, that's been known to slow down startup, especially if it's loading off a network share.
houdini -profile-startup=/tmp/startup.hperfYou can then load that file into the Performance Monitor for analysis.
Edited by johnmather - Feb. 21, 2025 23:23:46
- CYTE
- 802 posts
- Mirko Jankovic
- 279 posts
- D_Caps007
- 6 posts
I would like to offer you this information that can reduce the loading time (70s to 17s on Windows) of Houdini 20.5 :
1) SideFX Labs must be load in a single HDA.
2) Add Process = houdini.exe to Exclusions in windows anti-virus
(Note (Virus & threat protection settings -> Exclusions) recommends writing the process name with the full path)
source : https://ikatnek.blogspot.com/2025/01/houdini-startup-time.html [ikatnek.blogspot.com]
//* How to make this :*//
1) SideFX Labs load in a single HDA
If you download SideFX Labs from GitHub as a zip file and simply load the directory that was extracted, Houdini's startup time will drop significantly (by more than a minute).
Therefore, you need to bundle the various OTLs into a single file. To do this, use
$ hotl -m SideFXLabs-Development/otls/*.hda test.hda
(test.hda is the target file name) and load only this single HDA.
This will reduce startup time.
!!! Important : If you installed SideFX Labs from the old installer or Launcher, this step is not necessary because the related HDAs are already bundled into a single HDA.
2) Windows Virus & threat protection : Exclusion of the Houdini Process
Virus checkers have a large impact on Houdini's startup time. For example, I use the standard Windows Virus & threat protection for Windows 11, and
if I start Houdini 20.5.457 (including SideFX Labs single HDA) immediately after rebooting the system (OS), it takes 70 seconds.
However, if I add Process = houdini.exe to Exclusions and start Houdini after rebooting the OS in the same way, the time goes down to 17.6 seconds (see the top image), which is about 1/4.
Note that the official website (Virus & threat protection settings -> Exclusions) recommends writing the process name with the full path.
3) The following rule settings were not very effective.
Added Folder = "C:\Program Files\Side Effects Software" (reduced by about 2 seconds)
Added "otl", "hda", and "shelf" to File Type (increased and decreased)
//* End *//
//* End *//
Edited by D_Caps007 - Feb. 25, 2025 05:07:48
- coccarolla
- 136 posts
- alexmajewski
- 109 posts
@coccarolla According to that post, you need to use the hotl utility [www.sidefx.com]. You should be able to find it in your houdini install folder in bin/ ($HFS/bin). I haven't used it before, but it seems straightforward.
This is the line you need to recreate in your terminal (I assume you're on Windows, you can useCommand Prompt EDIT: this command requires Bash to work. Mingw64 Git Bash is one way to get a Bash terminal on Windows):
Breakdown:
In your case, the command could possibly look like this:
hotl -m SideFXLabs-Development/otls/*.hda test.hdaBreakdown:
hotlis the path to your hotl.exe -mis an instruction to merge hdasSideFXLabs-Development/otls/*.hdashould be the path to your SideFXLabs package. It uses a wildcard * to target all files that have an .hda extension in the otls/ foldertest.hdawill be the new HDA that hotl produces.In your case, the command could possibly look like this:
"C:\Program Files\Side Effects Software\Houdini 20.5.445\bin\hotl.exe" -m C:\mycustom_sideFXLabs_package_location/otls/*.hda "C:\Users\John\Desktop\single.hda"
Edited by alexmajewski - Feb. 25, 2025 07:50:16
- coccarolla
- 136 posts
- alexmajewski
- 109 posts
It could. But also make sure that if you have any spaces in paths that you encase them in double quotes. But in my case the command didn't work when I added double quotes to the SideFXLabs/*hda part, so perhaps that part needs to already be in a path without spaces to begin with.
Also, if you're trying to use it on something else than SideFXLabs I'm not sure if perhaps that /*.hda needs to be changed to /*.hdalc or /*.hda*.
Edited by alexmajewski - Feb. 25, 2025 04:16:01
- coccarolla
- 136 posts
alexmajewski
Thanks! I still get and error for these parameters: ...Documents\houdini20.5\packages\SideFXLabs-20.5.487\otls\*.hda" "...\Documents\houdini20.5\packages\labsSingle.hda"
Error is: Invalid or empty library for merge:...
Edited by coccarolla - Feb. 25, 2025 05:04:58
- alexmajewski
- 109 posts
I've just tested disabling Windows Defender. Excluding houdini.exe had ZERO effect in my case. But excluding an entire folder with my Houdini and all my Houdini packages (Redshift, Labs, etc.) made me go down from 01:30 to 0 0 : 2 3. This is crazy.
@coccarolla can you paste the whole command that you use?
Edited by alexmajewski - Feb. 25, 2025 05:13:57
- D_Caps007
- 6 posts
alexmajewski
@alexmajewski Hi, For information, I would like to point out that it is the Houdini process with its full path that needs to be added to the exclusion rules and not the Houdini.exe file.
