[COPS] Randomization in Tile Pattern node?
   2252   5   0
Hello!
I'm very new to COPs.
I was wondering if there's a way for me to plug both square and circle nodes into the stamp input? (As shown in the screenshot attached).
I'd want to randomize both of them in the TilePattern1 node.
Edited by pranesh arry - Sept. 1, 2025 16:14:37
Pranesh Arry
3D Generalist at North Studio
Figured it out - anyone looking for a solution:
- Unlock the node
- go to StampPoint node and use "Number of Stamps" parameter to add more stamps
- Go into SOPImport and add a "stamp" attribute; this is an int attribute (this attribute will choose which index of stamp to use, so you can randomise it).
More info here : Stamp Points [www.sidefx.com]
Pranesh Arry
I'm getting a bit lost adding the int to the sopImport area, would it be possible to share a working version of this node? Kinda can't believe they forgot to add this functionality xD
Watch this - everything explained by a master : )
https://youtu.be/FyhR1VYJ3N4?si=afd8ZdR-UaAJOvTC&t=2686 [youtu.be]
Mike_A
This is a useful video in general, but it doesn't solve the issue with the "tilepattern" node and not being able to input multiple inputs into the stamp slot.
Actually easier than I initially thought it would be, just put the attrib at the end of the sopimport chain, and an attrib randomize afterward
Your shapes can then go into a cable pack node
Edited by jjeverson - June 24, 2026 17:17:47
