I have a cube, that I want to copy to a grid, but have the cubes taller in the center, they would scale down as the got to the edge of the gird.
try to make a “city” like grouping of polys
any thoughts?
TIA
Random scale help
18782 10 3-
- ollieslats
- 14 posts
- symek
- 1390 posts
Reference in BoxSOP paremeter sizey (“Size”) in ty (“Center” in GUI). You can do this with drag and drop. Then divide it by 2. So in Center Y-axe field you should have something like: ch(“sizey”)/2.
Alternatively you could reposition pivot of a cube, for example with an expression like $YMIN which is valid in TransformSOP.
hope this helps,
sy.
hope this helps,
sy.
- goldfarb
- 3465 posts
read through this entire thread…then go back and download some of the sample files (some may not work 100% - H8 v H9)
you'll learn a ton about exactly what you're trying to do
http://forums.odforce.net/index.php?showtopic=3156&hl= [forums.odforce.net]
- ollieslats
- 14 posts
- probbins
- 1145 posts
- ollieslats
- 14 posts
- keyframe
- 1533 posts
- goldfarb
- 3465 posts
- ollieslats
- 14 posts
keyframe
You can simply replace the grid in Peter's example with a sphere.
Make sure you change the type to polygon (in the sphere sop)
Best,
Gene
One more thing them Im stopping for the night… my brain hurts.
If I still want to see the sphere that the boxes were copied to… like the ground they rest on, how would I do that.
Man this software is cool!
- keyframe
- 1533 posts
- goldfarb
- 3465 posts
