delay load and multi-materials
   3308   4   2
Hi all,
Is it possible to have more than one material assigned to a delay load object? I know I can store path to the material as an string attribute. But on the other hand once delay load is read I have to assign a new materail on the object level, otherwise I am getting black renders.
I will be gratefull if someone could explain me how delay load works and if it's possible to have several materials assigned to it? Thanks.
kuba
PS. Can I save bgeo as ASCII?
Czesc Kuba,
Add “Declare All Materials” from Edit Rendering Params in Mantra ROP and turn it on. You can also turn on “Force VEX Shader Embedding”, easier to manage render farm.
ASCII *.bgeo is a *.geo
cheers,
sy.
Yes, it is.
Be patient and I will create a simple simple example.
Stephen Tucker
VFXTD
SYmek
Czesc Kuba,
That was sort of: “Friday's evening” question, silly of me ops:
Dzieki Szymon
pozdro!
kuba
PS. “Declare all materials” - Didn't know it is so simple! I would never found it out though!
Just in case it's of use to anyone else…
DelayedLoadExample.zip (623.8 KB)
Stephen Tucker
VFXTD
