Hello!
I need someone that explain to me what is only one mantra token in Apprentice version? It means with the Appentrice version i can only do a single render of work? Make an AVI only one time?
Please…someone explain….
one MANTRA render token
17137 6 0- nunoagonia24
- 7 posts
- wolfwood
- 4261 posts
- nunoagonia24
- 7 posts
- peja_
- 4 posts
can anyone explain this a bit more please
I am considering to buy apprentice HD so I need to understand this:
ONE TOKEN - I can render as many times I want? It just means that I can't form render farms?
ALSO,
if I buy apprenitce HD, will I be able to install it on any platform I want (as long as I don't try to make render farm) - so if some day I wish to install it on a Linux machine, will I be able to?
Does that one token will still be there after reinstalling it (does it ‘last forever’)?
ALSO,
- silvina
- 181 posts
One mantra token means you can render one image at a time in your machine. Apprentice HD is not networkable, so, you won't be able to render on a farm, or open houdini in another machine.
You can install Apprentice HD in any platform. The licenses are your and they do not expire. If you want to upgrade/change machines at some point, you just need to “return the licenses” from the computer where they are installed and re-redeem from your new machine…
Please check our FAQs on how to return licenses…
http://www.sidefx.com/index.php?option=com_content&task=view&id=1208&Itemid=273#return [sidefx.com]
- silvina
- 181 posts
- peja_
- 4 posts
