how prevent my cube to go inside ???
   9783   14   1
hello all,
i have a new question…
i have some cube, i apply dynamic (RBD Object)
i play my movie…
my problem it's i have always the same problem..
i can't find how i prevent my cube to go inside..
i increase my division, i change mode: ray intersect, implicit box… nothing..
i try all possibility but always nothing… someone has a idea?
please
Try subdividing the box geometry.
RBD uses geometry points for collisions against the SDF. (heh, it's a wierd relationship )
ok, it's besser, thanks a lot…
there is not a function for block or stop collision before geometry?
1cm before or other?
I am not using DOP too much but in POPs in the collision POP there is a parameter “collision tolerance” which allows you to do that, I guess DOP must have it.
I think with something like a box you can use ‘implicit box’ for the mode - on the Volume > Collisions TAB…
HTH
Training Lead
www.sidefx.com
hello, thanks..
I try…
it's normal that simple cubes is very really long to calculate simulation?
i have 70 cube, my computer calculates 1 image every 8 seconds… it's normal for simple cubes?
You can also increase the Collision, Contact & Subcontact Passes values in the RBD Solver DOP to check for inter-penetration.
The other alternative is to use Edges to represent the geometry but that's slower.
Cheers!
steven
but it's this windows???
i don't found…
where it sayd Mode - change Ray Intersect
to Implicit Box
Training Lead
www.sidefx.com
supermac
Yes - Houdini RBD has no specific optimization for simple primitive shapes. Your object may as well be an octopus and it'll simulate with a similar speed.
hello thanks for your answer…
but i dont found windows for increase the Collision, Contact & Subcontact Passes values in the RBD Solver DOP to check for inter-penetration.
where is it? please…
They should be on the RBD Solver DOP
sorry.. but i new users…
where is RBD Solver DOP… i dont found…
have you a path for found this?
thanks a lot..
For that intersection issue, I guess you can try telling Houdini to use Edge representation (instead of Point) for collision detection… In your RBD Object DOP, Collision->Surface->Surface Representation. Would this help? The down side to this is………
your sim will slow down…
give this a try
boxes_DOPs.hip (114.3 KB)
Training Lead
www.sidefx.com
