rendering nurbs problem
   5722   7   1
I don't get Nurbs to render. A simple scene with a nurbs sphere won't render.
Using H 10.0.265.
Then I installed a version of H 9.5 and the problem stays…
Are there special parameters to render nurbs objects with Mantra?
If I render with Prman everything works…
thanks,
bern
houdini 10.0.257
open houdini
geo
sphere > NURBS
click “View : Mantra”
renders sphere…
can you post a hip?
Training Lead
www.sidefx.com
Thanks Arctor,
I'm working with an AMD Athlon XP 2400, maybe that"s the problem…
I will post a hip file.
bern
If I leave the “imperfect” option unchecked, the nurbs sphere does render…
thanks,
bern
Something to do with rational/non-rational surfaces then…. odd
I assume if you convert the one that doesn't render to polys all is well?
For the record, I'm running 10.0.266 on 64 bit linux and all variations of the NURBS sphere renders fine.
J.C.
John Coldrick
Simon
Hello Simon,
yes, if I convert to polys the render is fine.
What can be the cause of this…pc processor (AMD)?
thanks,
bern
Bernard
Simon
Offhand, I'm don't see why but you can test by setting these environment variables to 1.
HOUDINI_DISABLE_MMX
HOUDINI_DISABLE_XMMX
HOUDINI_DISABLE_SSE
HOUDINI_DISABLE_3DNOW
