since a while now I haven't gotten a chance to render an image sequence: when I fire up mantra the 1st image renders and then nothing
I've had this issue before which I used to solve by deleting the “houdini 9.5” directory (snow leopard)
but now with houdini 10 I can't find this directory anymore
I have tried several times to unistall and install again but nothing changes
does anyone have a clue?
many thanks
cheers
can't render image sequence anymore
12827 7 2- jlautret
- 34 posts
- stevenong
- 1631 posts
If you have the “Clear completed frames” toggle turned off in the Render Scheduler, Houdini always gets stuck on the first render frame. This has been logged as a bug since 9.5 but please submit [sidefx.com] it again.
Cheers!
steven
Cheers!
steven
- jlautret
- 34 posts
- ncic
- 8 posts
weird, i also just got this issue where mantra only outputs the first frame of the sequence. it goes through the entire render process but leaves only 1 frame.
with “Clear completed frames” in scheduler i suspect you mean “clear completed jobs”?
unfortunately that didnt fix it for me.
i also did an update to build 10.0.520 but still no go.
anyone else having this with the recent builds or having some work around.
hugs
s
hugs
s
- Soothsayer
- 861 posts
- ncic
- 8 posts
- ncic
- 8 posts
ok, i got the reply now
so, i had not named my file sequence correctly, how stupid of me ops:
maybe youre doing the same thing
just in case you dont know you need to add $F to the name
that way each frame will get a unique file name and will not overwrite the previous.
filename_1.png filename_2.png and so on
ops:
ops:
- arpitav
- 4 posts
