Not sure if I'm doing something wrong or not, but I can't get ICP to work
should be simple right?
> icp test.exr test.tif
shoud do it?
but I get the error :
Unable to create test.tif
Exit 1
permissions are fine, doing this in my home directory,
same issue with H10.0.295 and H10.0.430..
any ideas? I'm sorta stumped.
thanks
icp not working ?
4009 4 1-
- redpaw
- 75 posts
- redpaw
- 75 posts
Seems this is now also causing some other problems..
I think the same problem of icp not working, is also causing my deep shadow .rat maps to not convert during a render.. during non mplay window output , I get an error during the main render after the shadow map .rat file is created and when it seems like the renderer is trying to access it again.
mantra: Could not open imager
strangely enough when i run a “preview” to mplay render this is not a problem
but maybe during preview, it renders the rat file to a buffer in memory and not to disk?
not sure
anybody have any idea what this could be?
thx
-johnc
not sure
thx
-johnc
- mark
- 2602 posts
redpaw
shoud do it?
Exit 1
thanks
What does running “iconvert” with no command line options give you. It should list all the file formats available.
What platform are you on?
- redpaw
- 75 posts
iconvert seems to work, it spits out the help, and then a
“supported formats are…” with a list of everything as you describe.
we're running linux x64 on fedora 10 right now, so I don't know if that may make any difference..
is icp a wrapper for iconvert? I'm a bit new to the underworld of houdini command line helpers..
thx for the help tho, hope we can figure this out.
-john
-john
- jimc
- 295 posts
I came across after running into the same problem. I'm on Windows Vista 64bit Ultimate. I'm using Houdini Apprentice version 10.0.249.3,
Platform: windows-x86_64-cl14
OpenGL Vendor: NVIDIA Corporation
OpenGL Renderer: GeForce 8800 GT/PCI/SSE2
OpenGL Version: 2.1.2
When I try and convert a jpg to a .rat format I get the same error. iconvert does list RAT as a supported format. The help docs mention something about a ratnc format (I presume for hte Apprentice version, just like the hipnc project files). I tried “icp myfile.jpg myfile.ratnc” and that also failed with the same error.
