@buki and everyone: The display dropdown is what look like shades/glasses.
@cooly08: After you uninstall do you re-start your computer before installing again, and making sure that everything is deleted?
DJ
Trouble with null node...
14536 36 2- DJ_BOXER
- 57 posts
- cooly08
- 17 posts
- DJ_BOXER
- 57 posts
Are you going to the uninstall option or are you just deleting the folders/files? If you are just deleting then sometimes information remains in the Registry and elsewhere. If there is no uninstall option try going to add/remove programs in Windows Control Panel and try uninstalling it there.
DJ
DJ
“Nothing is just Black & White”- look at the Yin/Yang symbol
- cooly08
- 17 posts
- ManDay
- 40 posts
Ok, that you see the Control OP rendered is a good sign and means that your NULL node can be fixed one way or another. We just have to figure out how
Next test: Open the file attached (it's just a NULL node). Does this NULL render out correctly? If yes, we can be sure that it's just the tool that is broken and you'll (we) have to look into that
- cooly08
- 17 posts
Haha excellent MandDay, I love your message “Here should be your NULL:” in Houdini ^^
Yes it's working and yes it's the null tool itself who is broken. But why ? That's the question. Because, something else can be broken too. And it's very strange indeed ^^
I don't have the time now to install windows 7 from scratch but I will let you know when I do that.
- ManDay
- 40 posts
I wouldn't recomment overdoing your whole OS before you haven't checked out at least the first options you have. Dive into /houdini/scripts/python/objtoolutils.py and try out some things. I'vent gone through that file in all detail but it should boil down to a sequence of commands which lay down the container and a NULL obj inside. Once you have found them, try to run them one after one in Houdinis py-console and thus figure out which command exactly is causing the problem.
That's all the help I can give you so far. I'm not a python programmer myself but it appears to be a fairly simple script and you should be able to locate the crucial commands in question.
bonne chance
bonne chance
- graham
- 1908 posts
Looks to me like the problem is a result of the init scripts failing to be run. If there was a problem with the code in objecttoolutils then you'd be receiving Python errors and the tool wouldn't work at all. Maybe there is some sort of permissions error in $HH/scripts/? Does creating a Geometry object in the Network Editor give you the operator with the File SOP be created inside it?
- cooly08
- 17 posts
- graham
- 1908 posts
- cooly08
- 17 posts
graham > Here is the result :
http://tof.canardpc.com/view/c4ef1121-8d11-498c-ba85-4a2ad407d603.jpg [tof.canardpc.com]
- graham
- 1908 posts
So the null init script is being run. However it looks like it cannot source the $HH/scripts/obj/nullcontrol.cmd script. This is the script that actually creates the control and point nodes inside the Null object.
Does that file exist? Does it have read permissions?
- cooly08
- 17 posts
Yes the file exist and he's readable.
http://tof.canardpc.com/view/b958206c-d5e6-4c83-ad7a-e15af25ded44.jpg [tof.canardpc.com]
(I've added the hconfig result through the command line tool).
- graham
- 1908 posts
- cooly08
- 17 posts
- cooly08
- 17 posts
- Stalkerx777
- 183 posts
