Currently, if I resample a super high res curve, it spaces out each points by the exact same distance. Is there a way to have more points in complex areas? For example, if I resample a spiral curve, I end up with too many polygons on the outside and not enough points at the center.
In other words, is there an equivalent to Polyreduce but for curves?
-Olivier
More Adaptive Curve Resample?
1454 6 1-
- olivierth
- 1184 posts
- ajz3d
- 654 posts
Look for Ramer-Douglas-Peucker (RDP) algorithm. Fabian Hirschmann made a Python implementation [github.com], which is easily portable to an HDA. It's not too fast, but it works very well.
Edited by ajz3d - May 8, 2025 14:20:41
- ajz3d
- 654 posts
- olivierth
- 1184 posts
- cncverkstad
- 173 posts
node = hou.pwd() geo = node.geometry() epsilon = 0.5 class Point: def __init__(self, index, pos): self.index = index self.pos = hou.Vector3(pos) def douglas_peucker(points, epsilon): if len(points) < 3: return points start, end = points[0], points[-1] max_distance = 0.0 index = 0 for i in range(1, len(points) - 1): distance = point_line_distance(points[i], start, end) if distance > max_distance: max_distance = distance index = i if max_distance > epsilon: left = douglas_peucker(points[:index + 1], epsilon) right = douglas_peucker(points[index:], epsilon) return left[:-1] + right else: return [start, end] def point_line_distance(point, start, end): if start.pos == end.pos: return (point.pos - start.pos).length() line_vec = (end.pos - start.pos).normalized() point_vec = point.pos - start.pos d = line_vec.dot(point_vec) projection = start.pos + line_vec * d dist = (point.pos - projection).length() return dist points = [] index = 0 for pt in geo.points(): points.append(Point(index, pt.position())) index += 1 simplified_points = douglas_peucker(points, epsilon) result = [] for i in range(len(simplified_points)): result.append(simplified_points[i].index) geo.addArrayAttrib(hou.attribType.Global, 'result', hou.attribData.Int, 1) geo.setGlobalAttribValue('result', result)
int pts[] = detail(0, "result"); if(len(pts) > 0 && find(pts, @ptnum) < 0) removepoint(0, @ptnum);
Conservation of Momentum
- Konstantin Magnus
- 720 posts
The refine node reduces the number of points within a user-defined tolerance:
https://www.sidefx.com/docs/houdini/nodes/sop/refine.html [www.sidefx.com]
Labs offers resampling by density that can be set to curvature:
https://www.sidefx.com/docs/houdini/nodes/sop/labs--curve_resample_by_density-1.0.html [www.sidefx.com]
And for adaptive resampling I would accumulate the curvature along the curve and resample it.
Edited by Konstantin Magnus - May 10, 2025 09:29:54
- Mike_A
- 392 posts
