Hi guys,
i want to bake a displ map from a highres to a lowres mesh and ran into a problem. Certain areas of the rendered Height Map are just black. So i jumped into the Cop Node and found that as soon as the lives outside the 01 UV range the texture seems to be clamped.
Is there a way around that behavior, did i miss sth obvious? Attached a Screenshot for clarification ->
Thanks in advance!
Bake Textures Clipping Problem
1078 3 0-
- recomberlin
- 3 posts
- tamte
- 9434 posts
from the picture it looks like this issue which has to do with uv.z if by outside of 01 you refer to that
https://www.sidefx.com/forum/topic/102134/#post-450065 [www.sidefx.com]
- recomberlin
- 3 posts
- Genbu
- 1 posts
