Changing Position of Only One Point in VEX
   1219   9   1
Hi everybody,
Noob question but lines like @P.y = value changes the position(for example) of every point in the geometry. Assuming I am in point wrangle is there a way to change the P.y or other attributes of only specific points and not all of them?
You can use the Group and Group Type to specify your target points:
Thanks but this is not possible when I do not know the points in advance. My question is about situation that is not predictable. For example there is an if statement and we want to change some attributes for those points.
How can I enter that procedure to the body of vex?
Edited by fred_98 - Nov. 12, 2025 08:54:03
The way Animatrix has it set up is that the points listed in that group parameter will be the only ones affected by the wrangle code.
Those are point numbers he has listed. You don't have to predefine a group if you don't know ahead of time.
Also, with that set of point numbers as Animatrix has it, if you wanted you could also work on a subset of those defined point numbers with code:
if(@ptnum <= 24 && @ptnum <= 27) @P.y += 0.1;
I am aware of it and your solution does not help neither.
I do not know the index of the points(@ptnum) and the algorithm will dictate which points will be qualified.
I am looking for a procedure that will affect only some of the points of the geometry but I do not know which points exactly and the index of the points are the result of some searching and other computations.
You can include points in a group in one wrangle and then move just that group in another wrangle. Sometimes it is easier to split operations.
fred_98
Supposing that you are able to get point numbers after your searching process, you can use get/set functions to modify a specific point based on it's ID/number :
// get point position based on a given ID
vector position = point(0, "P", point_id);
// adjust position
position.y += value;
// set the position "P" attribute on geometry only on the given point ID
setpointattrib(0, "P", point_id, position);
Edited by ObeidaZakzak - Nov. 12, 2025 14:28:31
fred_98
why wouldn't if() condition work for you?
you can include any condition in there and the point will move only if the condition for any particular point is true, doens't have to be point number related
like if you want to move only points faster than certain speed:
if ( length(v@v) > 10 ) v@P.y += 1;
or for simple attribute to value comparisons you can directly use ad-hoc syntax in group field with group type set to corresponding class like:
@mask<0.5
which will run only on elements with "mask" attribute value less then 0.5
or you may need to be more specific how do you expect to specify te points you want to move if neither group nor generic if condition work for you
The reason that I could not clearly express my question was that I was trying to translate structure of arrays in C to VEX tamte.
The answer by Obeida Zakzak is similar to what I am looking but I am not very sure.
I will try to experiment with the answers and come up with better description.
Thanks to anyone responding.
VEX is best when used for processing elements in parallel and each element will figure it's own attribute values
however if you want to set values for other elements, it may be helpful to know this [www.sidefx.com] as those limitations may be confusing if you are not aware of them
