Dynamic Grid Animation with different growing objects
1008 10 0-
- Daniel75
- 11 posts
Hello everyone,
I am currently trying to recreate the project by Daria Togunova. However, I would like to incorporate different objects that animate according to their size, similar to how Esben Oxholm once demonstrated. How can I integrate the different objects into the dynamic grid and animate them in proportion?
I would greatly appreciate any help and a solution. Thank you very much.
The .hipcl File is attached
Here are the examples:
- probiner
- 372 posts
I don't know any of the people/references mentioned but I did share on Discord years ago, something that looks like it goes along with what you're exploring.
Message with file: https://discord.com/channels/230123485668573184/231830113304444928/693566634056482856 [discord.com]
In case you're not in the server yet: https://discord.gg/723NGrShdm [discord.gg]
Cheers
Cheers
Edited by probiner - Dec. 28, 2025 10:48:29
- EZiniT
- 88 posts
"How can I integrate the different objects into the dynamic grid and animate them in proportion?"
"matchsize" node is your best friend here, turn on scale to fit, turn off uniform scale
which will scale the input geometry to the bounds of the bounding box on the second input.
Basically it's a case of using a loop ect to run over each primitive in the dynamic grid, extrude to make
your bounding box of (whatever height), matchsize a given object to this, repeat....put an attribute on the grid
to be read at each loop iteration controlling which object to place in that grid if any, should be job done!
Cheers!
Cheers!
"Genius might be the ability to say a profound thing in a simple way." — Charles Bukowski
- Daniel75
- 11 posts
- Daniel75
- 11 posts
- EZiniT
- 88 posts
Daria Togunova has a nice tutorial of how to create a dynamic grid on youtube called "Creating a Dynamic Grid Animation in Houdini" I guess you have seen that, if not it's worth a watch.
To expand on the "matchsize" so you can see it in action, attached is an alternative simplified version of a dynamic grid and
how to use the "matchsize" node to fit different objects to each grid location.
This should be more helpful and give a starting point to go forward a bit easier.
Cheers!
Cheers!
- Daniel75
- 11 posts
- Umang_Raj
- 54 posts
- Daniel75
- 11 posts
- EZiniT
- 88 posts
Hello Daniel, looks like you have a plenty of material to work with now.
Attached is a minor update to my previous post improving the processing speed quite considerably by compiling the for loop.
Happy New Year!
Happy New Year!
- Daniel75
- 11 posts
