Apex camera has a weird problem!
   1171   7   0
Does it feel like the camera is getting blocked when Apex is constrained?
It works fine without constraints, but when constraints are added, a green dot blocks the camera?
Edited by guoli - Aug. 30, 2026 04:58:34
Edited by guoli - Aug. 30, 2026 05:37:03
That is the offset control that gets created when you add a constraint to do offset anim without needing any more setup. You can select it and hide it
warrenl
Thanks! I need to constrain the camera so it moves in sync with the car! I also don't know where to set the hidden green points, the configurecontrols node doesn't work there.
Edited by guoli - Aug. 31, 2026 14:11:16
屏幕录制 2026-09-01.mp4 (3.2 MB)
It's listed under the constraints under the selection sets. Hopefully this video will help
Constraint_control_offset.mp4 (27.3 MB)
I've made a change to automatically hide these controls and their associated constraints when you look through a constrained camera.
It'll be available in tomorrow's daily build.
warrenl
Wow, so that's how it is. Thank you. Wishing you great wealth
jonathangardner
So great! So efficient, love you all
