Cops Multi ROPs: Save All with One Click? {[SOLVED]}
   550   4   1
Hi!
I'm making an HDA to bake multiple textures (Diffuse, normals, rougness, etc). How can I have a single "Render" button that saves all ROPs?
Edited by olivierth - Sept. 28, 2026 11:02:44
-Olivier
In you HDA type properties add a 'Python Module' in the script tap, in that module make a function:
def SomeFunction(kwargs):
print(kwargs)
then add a button to your HDA's interface and add a callback to it like this:
hou.pwd().hm().SomeFunction(kwargs)
When you press the button you can see the arguments passed to it.. final code will be a more elegant version of this:
kwargs['node'].node("rop_comp1").parm("execute").pressButton()
kwargs['node'].node("rop_comp2").parm("execute").pressButton()
Edited by Jonathan de Blok - Sept. 28, 2026 04:04:02
More code, less clicks.
You dont need to write callback script, just channel reference their Render button to a single button on your HDA
Or create a ROPnet inside of your HDA, Fetch them all in there, merge and promote the render button on the Merge ROP
Similarly you can ROP Fetch them into a TOPnet
Thanks for the ideas!
I know nothing about python so I like the simple button reference to other buttons.
-Olivier
tamte
Nice! I didn't even knew that was a thing
Edited by Jonathan de Blok - Sept. 28, 2026 15:08:11
