I was wondering if there is a way to adjust the range of a parameter in an OTL based on another parameter. I just want to make it so that one parameter can't be moved outside the range of another parameter to safe gaurd against conflicting parameters. I thought maybe opparm might work but I can only get it to affect the value not the range.
Any ideas?
Dynamic ranges in an OTL
7060 6 4-
- jjstanley
- 124 posts
- Allegro
- 696 posts
- jjstanley
- 124 posts
- symek
- 1390 posts
- goldfarb
- 3466 posts
- jjstanley
- 124 posts
- Antoine Durr
- 321 posts
SYmekI've done similar stuff by having the channel's range be somewhat greater than the largest expected value, and then in a callback, resetting the parameter value to the min/max of what's allowable.
I think you can't do any expression in range's fields of HDA, but you definitely can change what does mean 0-1 range by multiplying it with some dynamically evaluated channel, parameter, expression and using it, instead your param.
