Is there anywhere documented a list of attributes that are available for override from the fur procedural (or just for use by the fur sop)? All I can do is look in the furstyle cvex code and take the attributes from there but I don't know if that's a full list of attributes.
regards
John
Attribute list (fur procedural)
3711 3 2- protean
- 72 posts
- old_school
- 2540 posts
- derrick
- 329 posts
protean
The help cards for the Fur SOP and Mantra Fur Procedural list all of the attributes they use (they both use the same set of attributes). Anything else used by a CVEX shader is specific to that shader. For example, “frizz” has no meaning to the Fur SOP. But if you use a Fur Style SHOP, the SHOP will use the “frizz” attribute if it exists when modifying each hair's shape.
- protean
- 72 posts
