The title sums it up!
I'm on linux and I'm trying to adjust display options per viewport (space + d) so i can load background images.
If i try to select another viewport (space + x) while the diplay options are open, nothing happens? Shouldn't it select the viewport that my mouse is over?
However if I close the display options window and try (space + x) it works as it should.
Is this by design in Houdini 6?
Thanks,
/Rick
Unable to select other viewports when display options open
6834 5 1-
- RickW
- 141 posts
- JColdrick
- 4140 posts
- RickW
- 141 posts
- wolfwood
- 4325 posts
Its probably due to your window manager configuration.
It depends on the focus policy of your mouse. For example the default in KDE 3.1 is “Click to Focus”. So if you hit “space + d” to bring up the display options, that window now has focus. When you move your mouse away from the display options back to the viewport are hit “space + x” that hotkey request is being sent to the active window. Which is still the display options window and not Houdini. If you change you focus policy to something like “Focus Follows Mouse” then when you move your mouse cursor over to the viewport Houdini will become “active” and “space + x” will work just fine.
The focus policy settings for KDE are in the Control Center.
Control Center -> Desktop -> Window Behavior.
Gnome should have a similar setting.
jim.
jim.
- JColdrick
- 4140 posts
- RickW
- 141 posts
