H9.1.179
Having trouble using the hasprim expression with a switch SOP. In the Select Input field I have 'hasprim(“group_name”,“node_path”,0)' however nothing happens - keeps evaluating to zero (see attached image). Am I using this incorrectly?
As a side note, leading up to this I'm using surfsect SOP … is there anyway to figure out when the two inputs intersect? some sort of trigger?
Thanks in advance.
Rob
hasprim expression
3928 4 0- rdms
- 201 posts
- edward
- 7732 posts
- rdms
- 201 posts
- graham
- 1908 posts
hasprim is an Hscript Expression function and your node language is set to use Python, which is why it says it's not defined when you remove the quotes. Right now, with the quotes, it's returning that string expression which is useless in the context of the parm and returning 0. Either changing the expression/node to Hscript, or wrapping it in a hou.hscriptExpression() should make it work.
- rdms
- 201 posts
graham
Thanks graham, that was the problem.
Rob
Digital Supervisor | Stargate Studios Toronto
Rob
