mplay on two's
3398 5 1- rdms
- 201 posts
- JColdrick
- 4140 posts
Ah, it's the File Requestor that's causing that, I rarely use it(or on twos for that matter! ) and haven't noticed that before. It shows up as
foo.$F4.tiff 1-100 by 2
which indicates that it sees there are missing frames, but it's enforcing a non-missing range as you point out. If you use a command line approach, that sequence loads properly. I say File Requestor bug, but perhaps someone knows of an envar or setting that fixes this.
J.C.
J.C.
John Coldrick
- Allegro
- 696 posts
- malexander
- 5161 posts
I suppose opinions may vary, but when there's a missing frame, I like to know about it in MPlay. You can change this however. Windows->Preferences, Missing Frames = “Use Nearest Frame”.
I thought at some point that loading by 2's automatically set the missing frames to “Nearest” or “previous” for you; perhaps this got lost when the new image chooser was born.
- JColdrick
- 4140 posts
Missing frame is fine, but the requestor is telling me that foo is on two's - and it's correct. There are no missing files. If it's 1-100 by *one's* and there's a file missing, then yes I'd like to know.
Yeah, it does seem like something got disconnected with the new requestor…
J.C.
J.C.
John Coldrick
- TSDIZ.COM
- 2 posts
what any options you set in Windows->Preferences, Missing Frames
support @ techtemplate.net
support @ TSDIZ.COM
support @ TSDIZ.COM
