hey i am trying to reproduce the 3dBuzz Tornado
and ther is a point where Houdini crashes everytime.
fairly simple setup:
create a circle -> change it to Polytype-> connect
a sort OP to randomize the Points -> connect a Points OP
now when i change the $TX to
$TX + (rand($FF *$PT +40)-0.5) and copy that to $TY
and i click into to change smth in that expression boing
Houdini crashes with a fatal error.
i tried it several times it happens evertime !
so my quest -> is it a bug ?
and
(for those who knew the 3dBuzzTut)
is there an other way to create randomized particles sticked
to the end of a nurbs curve so i can move the emitter with the
topPoint?
thanx a lot
cheerz de
-HEAVY-
HOUDINI crashes when changing an expression
10585 9 5-
- -heavy-
- 62 posts
Janko Kissel
Maya & Houdini Smoke and Demolition VFX-Artist
http://vimeo.com/heavyatvimeo [vimeo.com]
https://www.youtube.com/user/masterheavyone/videos [youtube.com]
- stevecullum
- 112 posts
- JColdrick
- 4140 posts
Wow, I've done the equivalent of that so many times over the years on Linux and never experienced a problem like that. I just tested now on win64 and it's fine. What platform? Version of Houdini?
To clarify - forget the tutorial but you get a crash describing simply what you've listed? Or do you need to have it driving a particle system and you're displaying that?
J.C.
J.C.
John Coldrick
- buki
- 1773 posts
hi!
I'm getting the crashes too, every 5 minutes, simply editing the expression on a point node, a bit annoying.
win32, xp sp2, intel quadcore, quadro fx 1500
daniel bukovec | senior fx td | weta digital
qLib -- http://qlab.github.io/qLib/ [qlab.github.io]
- edward
- 8171 posts
- Allegro
- 696 posts
For what it's worth, I'm noticing this on my home computer as well… I've come across this twice today trying to do a bbox expression.
On a translate node for example, I'll type
bbox(“../NODE”, D_XSIZE)
when I press enter after typing the expression *sometimes* Houdini will crash. But not always. I'm normally good at finding the reproducable ones… but this one is really hit and miss…
my machine is:
windows xp 64bit
Nvidia quadrofx 4400 (latest driver)
xeon quad core
the crashlog seems pretty short
my machine is:
windows xp 64bit
xeon quad core
Stephen Tucker
VFXTD
VFXTD
- anon_user_40689665
- 648 posts
- Sdickinson
- 1 posts
- keyframe
- 1534 posts
- JColdrick
- 4140 posts
Well at least I've finally been able to repro, it's so oddly sporadic. Just once, but it was the first time I tried actively to spring it. Positively windows-related, since I've never seen anything like that on linux(triggered it on vista 64, 178.13). Can't help but think it's a driver issue. Being sporadic, and in my case triggered with a brand spanking new hip, it's got to be some sort of timing problem.
J.C.
J.C.
John Coldrick
