I would like to know if is it posible to use python to change a HDA's Parameter Description?
What I want is to make some HDA's parameters invisible always I press a buttom and the way I'm thinking to do that is to toggle the “Invisible” option in the HDA's Parameter Description like in image below.
So, someone knows how to do that?
HDA - Parameter Description
3662 2 1- alves_mauri
- 18 posts
- Antoine Durr
- 321 posts
.otl files are “locked”. You can make changes to them, via hscript and I assume python. However, the changes are global to all instances of the operator (unless the operator comes in as unlocked or you manually unlock it).
From a broader perspective, it's not a very good idea, as you're creating user interface that's hidden but that needs to be accessed. The usual approach is to disable it using the disablewhen field. That way, the user sees that there's UI that can/should/might be tweaked, and can be accessed if the rest of the UI has the correct combo of buttons and menus turned on.
- graham
- 1908 posts
