ray type switch in Mantra?
   3262   0   0
in mentalray there is a Ray Type Switch node which determines how the surface will look for different rays (eye, reflection, refraction, GI, …)
for example
i plug green shader into eye input of the ray type node
red shader into reflection input
blue into refraction input
yellow into GI
and when rendered, the surface will be green, but when you see it reflected in another object it is red, when it is behind a transparent surface it is blue and it casts yellow color in GI
is something similar acheivable in Mantra? (in one pass of course)
FX Supervisor
Method Studios, NY
