where can I change the mass of particle fluid?
   3259   4   0
thanks for any anwsers.
^_^
I believe Particle Fluid mass is defined by Rest Density, it uses that to determine how forces act on it(and how it acts on other things, I would imagine). It's in the Particle Fluid Object DOP.
J.C.
John Coldrick
thanks….
and, I used the whitecap on the shelf of 9.5, there is no mass attribute from the particle fluid dop network. So I think there should be a place to set the mass attribute?
^_^
I believe it's set to default of 1, once in the popnet it's like any other particle system, you can override it's mass there.
J.C.
John Coldrick
Thank you J.C
^_^
