keyframe interpolation programing
   6770   4   1
Hi All!
I´ve some questions about channels. programming for custom keyframe interpolation.
1. Is it possible to write a custom Keyframe interpolation function for a channel segment?
What is the syntax?
2. Is it possible to export animation from character so as it is, I mean not samples but really keyframes, as it was animated by animator? Like a animation clips in Maya. I tried to export with Channel ROP also from Channel editor´s menu and I got just a animation with keyframe in each frame.
3. Isit possible to change a Keyframe interpolation for all keys form the same frame direct on the playbar (Also like in Maya, sorry )
Thank you all in advance! :?:
stass3d
Hi All!
What is the syntax?
I can try to answer the first one:
You can write any expression in the hscript expression language.
Simple expressions just use $T or $FF to determine motion, like
sin($T*80)
However, there are local variables for keyframe values ($IV is the value at the beginning of the segment, $OV is the output value, $IT is the the start time, $OT is the end time, $LT is the local time, etc.) So for example, you could emulate the linear() function using
fit($LT, $IT, $OT, $IV, $OV)
Alternatively, you can use the python expression function (pythonexprf) from within an hscript expression to evaluate python. Variables within a double quoted string will be expanded, so you can do something like:
pythonexprf(“float($FF)”)
or
pythonexprf(“hou.frame()”)
Another alternative is to set the evaluation type for a channel to python, in which case you can just write Python for channel evaluation (i.e. reading from some USB input device, or using a socket to read values, etc.)
And lastly (I think), you can write a C++ function which extends the hscript expression language. There are examples of this in the HDK sample code.
I hope this helps.
2. In chops use a spline chop after fetching the channel that you want to export, then save that out as a .chn or .bclip.
I don't use Maya, so I don't know who it will be imported.
3. No, the keys you see on the playbar act as a dope sheet.
“everything is coincident”
stass3d
Scope the channels you want in the Channel View pane. From the Channel View pane tab menu, choose Channels > Export Displayed Channels As…
Thank you all!!!!
its very helpfull!
