Hi all,
I'm trying to override the material assigned in SOPs with the OBJ level material. Which parameter from Edit parameters interface controls that? I can't find any.
Thanks.
sop level material override
2594 1 0- kuba
- 345 posts
- mark
- 2597 posts
kuba
Hi all,
Thanks.
vm_overridedetail - Ignore Geometry Attribute Shaders
I believe this can only be assigned as an object level property, and it causes mantra to ignore all SOP level materials.
If you don't assign a material at the SOP level though, it should pick up the object level material which might be an easier way to do it – depending on what you're trying to do of course.
