hi all, i'm unclear about xb format in coordinates parameter?, example i enter 0b in, the Node pop error, but use int number(ex. 0b) is normal(uv greater than 1??), is it cant use the float number?
any one can explain it,
thanks,
About curve SOP coordinates parameter,
5492 3 0- onlyoneHai
- 17 posts
- tamte
- 8594 posts
from the docs: "xb : For example, 0b…. Creates a point at breakpoint (u,v) of the surface number x in the input geometry."
so the are not the uv parameters of the input surface, they are IDs of breakpoint in u/v direction
thats probably what b in xb means, breakpoint
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- onlyoneHai
- 17 posts
- tamte
- 8594 posts
not exactly
xb will read x-th primitive of the input surface (NURBS/bezier) and position the curve point to u-th breakpoint in u direction and v-th breakpoint in v direction
pn will position the curve point directly to point number n (polygon/curve)
i am not the master in this subject, i just opened help and tried it in a simple scene to see what it does, so it may be something deeper under the surface what i am not aware of
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
