paint operator?
   3896   7   0
I have a small query and that is how to subdivide geometry with The help of paint operator
__________________
….Good Thoughts….
….Good Words……..
….Good Deeds……..
__________________
One way is to paint an attribute and then create group from that attribute. Now you can subdivide using that group. I've attached a simple .hip file. Sorry for the non-commercial file.
paintBreak.hipnc (41.7 KB)
Thanks Edward for quick reply.
Same kind of result I already tried.
Is there any way to use paint operator for infinite. Min whenever we repaint on subdivided area it has to be get subdivided again and again.
__________________
….Good Thoughts….
….Good Words……..
….Good Deeds……..
__________________
I'm not sure I understand what you mean. Perhaps you want to apply your group using a Crease SOP first before piping into a Subdivide then?
Not exactly, with the same paint operator it has to be get subdivide geometry & if I paint on subdivided region it has to be get re – subdivided.
__________________
….Good Thoughts….
….Good Words……..
….Good Deeds……..
__________________
If I understand correctly, no you can't use the same paint sop to re-select geometry to be sub-divided a second time.
The paint operation is used to select geometry and the geometry is either inside the group or not.
You will need a second paint operator to paint a new selection within your original painted group, then a new sub-divide sop to sub-divide your new group.
“everything is coincident”
Here's my meager attempt. It uses a ForEach SOP to repeatedly subdivide the geometry according to the break attribute and the current loop iteration.
paintBreak2.hipnc (52.3 KB)
U R Rocking Edward… my brain just get stuck around using ForEach Operator from many days , & simply u take me out from same . many many thanks
__________________
….Good Thoughts….
….Good Words……..
….Good Deeds……..
__________________
