I was trying to use occlusion() to make ambient occlusion with vex. I used to make occ in prman with occlusion(). In prman ,the occlusion() is the float, the vex, it is the vector, I think they are “nearly” the same.
I wanted to make the surface occlusion shader, with cf = occlusion(P,N); it didn't work as occlusion() in prman, it rendered all black, but I think it caculated the occlusion(), because it is not as fast as a plasitc shader.
occlusion() fails?
2546 2 1- ykcosmo
- 288 posts
- symek
- 1390 posts
ykcosmo
There are two versions of occlusion in VEX. The one you use returns colour:
vector occlusion(vector P, vector N)
second one returns float:
void occlusion(float coverage&, vector missed_direction&, vector P, vector N)
You see black render, because the first one needs a background color or an environmental map that is a source of “light” once ray won't hit a surface. Both are an optional parameter for occlusion() call as described here:
http://www.sidefx.com/docs/houdini9.5/vex/contexts/shading_contexts#rayopts [sidefx.com]
Check the code of VEX GI shader for example usage.
sy.
- ykcosmo
- 288 posts
