hi~ everybody
i got a problem….i want to interact the keyframe animation and dynamics animation together in houdini in order to reduce the computation and speed up the kinetic simulation, but i didn't make it. for example, box1 move from the right side of table to another side of table by keyframe, box2 falling from the sky by dynamics and collide with the box1 at the middle of the table. How to make it? :cry: :cry:
interact the keyframe animation and dynamics animation??
3018 2 3- VFXCSN0309
- 14 posts
- RBD_ID039
- 17 posts
- keyframe
- 1532 posts
Have a look at the blend solver. It allows your to blend between two solvers.
One solver will import animated data from sop, while the other will inherit those attributes, and apply them to an RBD solution.
Obviously these will be blended based on another piece of data allowing you to transition smoothly between them.
IIRC the blend solver has a helfcard.
G
G
