I'm having problems with the Convert function. I'm using Houdini with TGE for modelling, so everything has to be in triangles.
And I've run into a problem.
I tried something mentioned in the DTS node info, namely using a Convert in order to, well, convert my modell into triangles.
But it doesn't work, it seems to convert only some parts of the modell.
I've set it to “From Type: All” and “Convert To: Polygon” as well as Connectivity: Triangles
From what I understand, that should do it.. but it doesn't. I just started with a box, Polygon Mesh and Triangles and went from there, and in the end needed the converter. It's not a real model, it's a test thing.
New Reality Company Stereoscopic displays, software, solutions, products.
