Animating particle fluids
   2508   2   0
Hi there!
I´ve been trying to animate some parameters in the particle fluid solver, like “Plasticity constant” and I have the impression that although the parameter accepts an expression like
if($FF>20,1,35)
it really doesn´t animate the parameter within the solver.
Can anyone confirm, please? or perhaps I should write to sesi?
Try:
- RMB on particlefluidsolver -> allow editing of contents
- dive inside particlefluidsolver
- show parameters for gasadjustelasticity1 node
- change the listbox in front of Plasticity Constant from “Use Default” to “Set Always”
and likewise for other parameters you want to animate.
eetu.
