Hi
I just purshased a car model in obj format and Houdini can't load the geometry
it only tells me “unable to read” the file
how can I find more infos about that, so I can explain the turbosquid online help to figure out the issue
thank you for your time
(ps: the file is 45Mb so I don't think it's a good idea to upload it for testing)
can't open a .obj model
10064 10 0-
- jlautret
- 34 posts
- JColdrick
- 4140 posts
Well, if you purchased it, it's copyrighted so don't upload it here regardless.
OBJ files are probably the least challenging file format to import into Houdini - I suspect either the file is still compressed(zip gzip etc), something corrupted the download(make sure you aren't using a downloader, just your browser), or there are file permission issues.
You're loading it in with a File SOP, right?
If you get really stuck and you have support with SESI, you can contact them and perhaps arrange uploading to a secure area where they can test it.
J.C.
J.C.
John Coldrick
- jlautret
- 34 posts
yeah I load the geometry in a file SOP and nothing happens
I use apprentice HD actually, this project is for personnal training so I just can expect help from turbosquid or you…
I know you can't really fix it but I was just wondering if I oculd get some info somewhere like in the textport or something, so I can send a bug report to turbosquid to help them to fix that.
what kind of format can I use besides .obj and fbx by the way?
is there a trick to import .ma or max objects?
thanks for your support
regards
regards
- wolfwood
- 4344 posts
- edward
- 8081 posts
- wolfwood
- 4344 posts
edward
@Wolfwood: You should send it into support if you haven't already.
I did.
And after a few weeks of UTR we chalked it up to bad karma. It only happened on windows, if $HOME was in the root of a networked drive, and only then under specific conditions. I had a few other people, aside from Support, try to reproduce it and they couldn't either.Sadly I lack windows debugging skills so I gave up.
:cry:
- jlautret
- 34 posts
thank you for your interest…
I would love to try all this but I'm absolutely not familiar with those functions
I've been trying for like an hour to figure out how to run gwavefront, I can't find any help, I mean readable help by someone who is not a programer…
where should I start? buy a book about linux language? (if this is linux language)
I can see scrolling down the help page that houdini is full of utilities but there's nothing telling the basics about them
if you feel like helping a noobie :-)
thank you guys
thank you guys
- JColdrick
- 4140 posts
It's a command line utility that ships with Houdini, nothing to do with Linux. Just cd to the houdini install directory, the ‘bin’ folder in there, and run it from a DOS shell(assuming you're on windows). If on linux, then run from a shell. If you run it with no parameters it gives you a little help. Should be in the help too.
It's unlikely it will help you, but it might, it was more of a diagnostic thing. I'd check out what Edward suggested…
J.C.
J.C.
John Coldrick
- jlautret
- 34 posts
- jesta
- 311 posts
- jlautret
- 34 posts
hey
ok so I tryed via gwavefront with no result
I mean it wasn't able to read the file
but I also downloaded the model in C4D format (which worked well in C4D) and converted in wavefront with C4d and now it seems to work in Houdini (I get all the polygon groups and everything)
maybe the file was corrupted, but I also tryed to convert a .obj file which was working great and gwafront “wasn't able” to save it in .geo or .begeo
sooo.. I dunno hehe
but I can read the model in Houdini now so that what matters
thank you for all your answers anyway and I will keep looking up for thoses standalone applications with more interest
thank you all
cheers
sooo.. I dunno hehe
thank you all
cheers
